vlr-window-reactor
(vlr-window-reactor customData
callbackList)
This function creates and attaches a Window
operation reactor to the current drawing, for the command events
specified by callbackList.
Arguments
customData
(any valid Lisp data) custom data to be
associated with the reactor object, can be NIL
callbackList (list) list of DottedPair entries, each
DottedPair has the form
(event
. callback)
event : one of
these symbolic constants
:vlr-docFrameMovedOrResized
a document window was moved
and/or resized
:vlr-mainFrameMovedOrResized
the main window was moved
and/or resized
callback : the
client Lisp side callback function, using 2 arguments :
(defun MyCB ( reactor args
reactor : the
window reactor object - #<VLR-Window-Reactor>
args : (list)
contains 1 or more arguments depending on the particular event
2 arguments
1st argument : (integer) the HWND window
handle of the affected window
2nd argument : (symbol T/NIL) : T indicates a
moved window, NIL indicates a resized window
Return
the reactor object
#<VLR-Window-Reactor> or NIL
Example
Remarks
