Since V23, BricsCAD LISP
provides a dedicated interface for the Parametric + Mechanical
functionality (requires "Professional"
resp. "Mechanical" license).
This new API part is designed for simplicity,
flexibility and following the usual AutoLISP logic in naming,
arguments, behaviour and results.
As Parametric functionality requires the
BricsCAD Professional ("PRO"), the Mechanical functionality
requires the Mechanical license level, using a lower-level license
(or when disabled i.e. by RunAsLevel=0), the API module is not
active, and all Parametric + Mechanical LISP API functions will not
be available.
As Parametric/Mechanical development
constantly continues, the BRX and LISP APIs will also expand,
providing more functionality and also incorporate the ideas and
feedback from third party developers.
The Parametric/Mechanical LISP API has 2 parts
a) the Rhino-Import/Export, Mechanical
Components, MechanicalComponent Instance
and MechanicalComponent
Definition functionality : these require
the "Mechanical" license level
b) the 3D Constraints
Groups, 3D Constraints and 3D Constraints Parameters
Functions functionality : these require
the "Professional" license level
How to verify the License Level ?
There are 2 Lisp functions
available : (bcad$LicenseLevels) and (vle-licenselevel),
which both use identical implementation.
If Mechanical is available, the returned list
will contain the string "Professional" resp.
"Mechanical".
"RunAsLevel" setting is also respected in
result list.
How to activate the Parametric+Mechanical LISP API ?
As the LISP function set for
Parametric/Mechanical functionality is implemented using the BRX
core system, it is required to explicitly load / activate the
Parametric/Mechanical LISP interface functions (somewhat similar to
required (vl-load-com) under AutoCAD AutoLISP) using :
If the context conditions
(Professional resp. Mechanical licenses) are met, it will load the
extension and return 1 (Pro functionality is available) or 2
(Mechanical functionality is available) or NIL if neither Pro nor
Mechanical license is available; in latter case, the specific LISP
functions are not available.
Some general hints & rules
"entity name"
usage : in all cases, when a functions
requires an "entity name", both "classic ename" and "vla object"
are always valid and supported.
The Mechanical API covers the following
functional areas :
New for V24 :
Since the Parametric
functionality is no longer strictly bound to the
Mechanical/Components interface, but rather a more generic
3DConstraints functionality, the former "mech::" related functions
for Parametric have been renamed using the "param:" prefix
To keep backward compatibility, all those
former "mech:" functions are still present (and will remain present
!) as a kind of alias, hence existing code will continue to work
without any hassle.
