AttributeReference object
Class AcadAttributeReference
Member of BricscadDb
Text that links to a block. An object containing text that links to a block. You cannot directly create an Attribute Reference. Attribute references are added to the drawing when a block containing an attribute definition is inserted into the drawing. To access an attribute reference of an inserted block, use the GetAttributes method. This method returns an array of all attribute references attached to the inserted block.
To access the AttributeReference object, use the following methods and properties.
Methods Properties
ArrayPolar Alignment
ArrayRectangular Application
Copy Backward
Delete Constant
GetBoundingBox Document
GetExtensionDictionary FieldLength
GetXData Handle
Highlight HasExtensionDictionary
IntersectWith Height
Mirror Hyperlinks
Mirror3D InsertionPoint
Move Invisible
Rotate Layer
Rotate3D Linetype
ScaleEntity LinetypeScale
SetXData Lineweight
TransformBy Material *
Update Normal
  ObjectID
  ObjectName
  ObliqueAngle
  OwnerID
  PlotStyleName
  Rotation
  ScaleFactor
  StyleName
  TagString
  TextAlignmentPoint
  TextGenerationFlag
  TextString
  Thickness
  TrueColor
  UpsideDown
  Visible
