Block Refercence object
Class AcadBlockReference
Member of BricscadDb
The BlockReference (=BlockInsert) object represents an instance of a block definition inserted into a drawing. To create a block reference, use the InsertBlock method. To query or edit an existing block reference, use the following methods and properties:
Methods Properties
ArrayPolar Application
ArrayRectangular Color
Copy Document
Delete EffectiveName
Erase
Handle
Explode HasAttributes
GetAttributes HasExtensionDictionary
GetBoundingBox Hyperlinks
GetExtensionDictionary InsertionPoint
GetXData Layer
Highlight Linetype
IntersectWith LinetypeScale
Mirror Lineweight
Mirror3D Name
Move Normal
Rotate ObjectName
Rotate3D Parent
ScaleEntity PlotStyleName
SetXData Rotation
TransformBy Visible
Update XScaleFactor
  YScaleFactor
  ZScaleFactor
