DimAngular object
Class AcadDimAngular
Member of BricscadDb
A dimension measuring the angular distance between two lines or between the angle of a circular arc. To create an angular dimension, use the AddDimAngular method. To access the Dim3PointAngular object, use the following methods and properties:
Methods Properties
ArrayPolar AngleVertex
ArrayRectangular Application
Copy Arrowhead1Block
Delete Arrowhead1Type
GetBoundingBox Arrowhead2Block
GetExtensionDictionary Arrowhead2Type
GetXData ArrowheadSize
Highlight DecimalSeparator
IntersectWith DimensionLineColor
Mirror DimLine1Suppress
Mirror3D DimLine2Suppress
Move DimLineInside
Rotate Document
Rotate3D ExtensionLineColor
ScaleEntity ExtensionLineExtend
SetXData ExtensionLineOffset
TransformBy ExtLine1EndPoint
Update ExtLine1StartPoint
  ExtLine1Suppress
  ExtLine2EndPoint
  ExtLine2StartPoint
  ExtLine2Suppress
  Fit
  ForceLineInside
  Handle
  HasExtensionDictionary
  HorizontalTextPosition
  Hyperlinks
  Layer
  Linetype
  LinetypeScale
  Lineweight
  Measurement
  Normal
  ObjectID
  ObjectName
  OwnerID
  PlotStyleName
  Rotation
  ScaleFactor
  StyleName
  SuppressLeadingZeroes
  SuppressTrailingZeroes
  TextColor
  TextFill *
  TextFillColor *
  TextGap
  TextHeight
  TextInside
  TextInsideAlign
  TextMovement
  TextOutsideAlign
  TextOverride
  TextPosition
  TextPrecision
  TextPrefix
  TextRotation
  TextString
  TextStyle
  TextSuffix
  ToleranceDisplay
  ToleranceHeightScale
  ToleranceJustification
  ToleranceLowerLimit
  TolerancePrecision
  ToleranceSuppressLeadingZeroes
  ToleranceSuppressTrailingZeroes
  ToleranceSuppressZeroFeet
  ToleranceSuppressZeroInches
  ToleranceUpperLimit
  TrueColor
  VerticalTextPosition
  Visible
