Class AcadDimRotated
Member of BricscadDb
A dimension measuring the radius of a circle or arc. To create a radial dimension, use the AddDimRotated method. To access the DimRotatel object, use the following methods and properties:
Methods | Properties |
ArrayPolar | AltRoundDistance |
ArrayRectangular | AltSuppressLeadingZeroes |
Copy | AltSuppressTrailingZeroes |
Delete | AltSuppressZeroFeet |
Erase | AltSuppressZeroInches |
GetBoundingBox | AltTextPrefix |
GetExtensionDictionary | AltTextSuffix |
GetXData | AltTolerancePrecision |
Highlight | AltToleranceSuppressLeadingZeroes |
IntersectWith | AltToleranceSuppressTrailingZeroes |
Mirror | AltToleranceSuppressZeroFeet |
Mirror3D | AltToleranceSuppressZeroInches |
Move | AltUnits |
Rotate | AltUnitsFormat |
Rotate3D | AltUnitsPrecision |
ScaleEntity | AltUnitsScale |
SetXData | Application |
TransformBy | Arrowhead1Block |
Update | Arrowhead1Type |
Arrowhead2Block | |
Arrowhead2Type | |
ArrowheadSize | |
Color | |
DecimalSeparator | |
DimensionLineColor | |
DimensionLineExtend | |
DimLine1Suppress | |
DimLine2Suppress | |
DimLineInside | |
Document | |
EntityName | |
ExtensionLineColor | |
ExtensionLineExtend | |
ExtensionLineOffset | |
ExtLine1Suppress | |
ExtLine2Suppress | |
Fit | |
ForceLineInside | |
FractionFormat | |
Handle | |
HasExtensionDictionary | |
HorizontalTextPosition | |
Hyperlinks | |
Layer | |
LinearScaleFactor | |
Linetype | |
LinetypeScale | |
Lineweight | |
Measurement | |
Normal | |
Parent | |
PlotStyleName | |
PrimaryUnitsPrecision | |
Rotation | |
RoundDistance | |
ScaleFactor | |
StyleName | |
SuppressLeadingZeroes | |
SuppressTrailingZeroes | |
SuppressZeroFeet | |
SuppressZeroInches | |
TextColor | |
TextGap | |
TextHeight | |
TextInside | |
TextInsideAlign | |
TextMovement | |
TextOutsideAlign | |
TextOverride | |
TextPosition | |
TextPrecision | |
TextPrefix | |
TextRotation | |
TextString | |
TextStyle | |
TextSuffix | |
ToleranceDisplay | |
ToleranceHeightScale | |
ToleranceJustification | |
ToleranceLowerLimit | |
TolerancePrecision | |
ToleranceSuppressLeadingZeroes | |
ToleranceSuppressTrailingZeroes | |
ToleranceSuppressZeroFeet | |
ToleranceSuppressZeroInches | |
ToleranceUpperLimit | |
UnitsFormat | |
VerticalTextPosition | |
Visible |
© Bricsys NV. All rights reserved. |
