Class AcadTolerance
Member of BricscadDb
The Tolerance object represents geometric tolerance. To create tolerance, use the AddTolerance method. To modify or obtain information about a Tolerance object, use the following methods and properties:
Methods | Properties |
ArrayPolar | Application |
ArrayRectangular | DimensionLineColor |
Copy | DirectionVector |
Delete | Document |
GetBoundingBox | Handle |
GetExtensionDictionary | HasExtensionDictionary |
GetXData | Hyperlinks |
Highlight | InsertionPoint |
IntersectWith | Layer |
Mirror | Linetype |
Mirror3D | LinetypeScale |
Move | Lineweight |
Rotate | Normal |
Rotate3D | ObjectID |
ScaleEntity | ObjectName |
SetXData | OwnerID |
TransformBy | PlotStyleName |
Update | ScaleFactor |
StyleName | |
TextColor | |
TextHeight | |
TextString | |
TextStyle | |
TrueColor | |
Visible |
© Bricsys NV. All rights reserved. |
