Sets or returns the coordinates of one of the following entities:
3Dface, Leader, LWPolyline, PointEntity, PolyfaceMesh, PolygonMesh, Polyline, 3Dpolyline, Solid or Trace.
Syntax
Where:
objectVariable is a variable for storing the coordinates.
object is the entity object for which you set or return the coordinates.
Examples...
© Bricsys NV. All rights reserved. |
