acet-ui-table-name-get-dlg
(acet-ui-table-name-get-dlg
lstParams)
This function allows to select one or more
Table or Dictionary entries, using a dialog;
it calls (acet-ui-table-name-get-cmd)
internally if CMDDIA is set to 0, or if there is any other "outer"
command running incl. script file,
under such conditions, the commandline version
is automatically used.
lstParams : (list) list of parameters which specify the behaviour of
(acet-ui-table-name-get-dlg) function
lstParams parameters list : (title default tableName|dictionaryName [ flags [ filter [ helpfile [ helptopic ] ] ] ])
see (acet-ui-table-name-get) for more details on the lstParams parameters
