acet-ui-table-name-get
(acet-ui-table-name-get
lstParams)
This function allows to select one or more
Table or Dictionary entries, using a dialog or the
commandline;
it calls (acet-ui-table-name-get-dlg) or
(acet-ui-table-name-get-cmd) internally.
if CMDDIA is set to 0, or if there is any
other "outer" command running incl. script file, then the
commandline version is used.
lstParams : (list)
list of parameters which specify the behaviour of
(acet-ui-table-name-get) function
lstParams parameters list : (title default
tableName|dictionaryName [ flags [ filter [
helpfile [ helptopic ] ] ] ])
title |
(string) the title of the dialog (if the dialog is used; not used in commandline version) |
default |
(string) the default value being selected in the dialog's list |
tableName |
(string) the name of the Table (like Layer, Block, Linetype ...), or the name of a root dictionary |
flags |
(integer) (optionally)
integer bit values controlling the behaviour, default is
0 |
filter |
(list) (optionally) |
helpfile |
(string) (optionally) the help file to be used on "Help" button, and F1 key; same as in (help) functions |
helptopic |
(string) (optionally) the help topic to be used on "Help" button, and F1 key; same as in (help) functions |
see (acet-ui-table-name-get-dlg) and (acet-ui-table-name-get-cmd) functions
