bim:create-propertyset
(bim:create-propertyset name label
visible perInstance [categoryId |
categoryName])
This functions create a new PropertySet
name inside the
(optionally) specified NameSpace.
Arguments
name (string) the name of the PropertySet to be
created
label (string) the GUI label for the PropertySet; if
specified as empty string, the name will be used
automatically
visible (T/NIL) specifies whether the
PropertySet name will be visible or hidden
perInstance (T/NIL) specifies whether the
PropertySet name will be "per object instance" or applied to any BIM
object
(optional)
specifies the NameSpace where the new
PropertySet is attached to (each category has an associated
NameSpace)
categoryId BIM property category ID, can be omitted
(bcBimCategoryUser is used then); see Category Constants
---or---
categoryName BIM property category name as string, can be omitted
(bcBimCategoryUser is used then), see Category Constants
if omitted, the "User" NameSpace is
automatically used for the PropertySet
Return
T or NIL, indicating success
or failure
Example
"TestSet" "---test---" T T) T
(bim:create-propertyset "TestSetX"
"---testX---" T T bcBimCategoryIFC2x3) T
(bim:create-propertyset "TestSetZ"
"---testZ---" T T "MyPropertyNameSpace") T
Remarks
the "visible" status means
whether the PropertySet is visible in PropertiesPanel;
if the NameSpace (as indirectly specified by
categoryId resp. categoryName) does not exist, it will be
automatically created, as a visible NameSpace
