bim:delete-propertyset
(bim:delete-propertyset name
[categoryId | categoryName])
This functions deletes the specified
PropertySet name from the (optionally) specified NameSpace.
Arguments
name (string) the name of the PropertySet to be deleted
(can specify the "name" or the "label" of a PropertySet)
(optional)
specifies the NameSpace to remove the
PropertySet from (each category has an associated
NameSpace)
categoryId BIM property category ID, can be omitted
(bcBimCategoryUser is used then); see Category Constants
---or---
categoryName BIM category name as string, can be omitted
(bcBimCategoryUser is used then), see Category Constants
if omitted, the all NameSpaces are
automatically scanned to find the PropertySet "name"
Return
T or NIL, indicating success
or failure
Example
"TestSet") NIL
(bim:create-propertyset "TestSetZ"
"---testZ---" T T "MyPropertyNameSpace") T
(bim:delete-propertyset "TestSet")
NIL
(bim:delete-propertyset "TestSetZ"
Remarks
the PropertySet name/label is
case-insensitive;
if the NameSpace (as indirectly specified by
categoryId resp. categoryName) does not exist, NIL is
returned;
Please note, that some of the predefined,
built-in PropertySet(s) can not be deleted
