bim:get-assigned-space
(bim:get-assigned-space ename
[asObject])
Returns the string name or entity name of the
'Space', to which the specified entity is assigned to, or NIL if
that entity is not assigned to a 'Space' object.
Arguments |
ename the entity to query, as normal entity or as VLA
object name |
Return |
the space name (as string), resp. the space entity name, or NIL if the entity is not assigned to a space object |
Example |
(bim:set-assigned-space ent
"Floor") T |
Remarks |
important :
the name of a space is not unique ! Unique
identifiers are the GUID and also the "Number" of the
space; |
