bim:set-assigned-space
(bim:set-assigned-space ename
[name|object])
Assigns the specified entity to a particular
'Space' object, which can be defined by its string name or its
entity.
Arguments |
ename the entity to query, as normal entity or as VLA
object name |
Return |
T if assignment was successful, NIL otherwise (i.e. specified space does not exist) |
Example |
(bim:set-assigned-space ent
"Floor") T |
Remarks |
important :
the name of a space is not unique ! Unique
identifiers are the GUID and also the "Number" of the
space; |
