bim:pset-create-property
(bim:pset-create-property psetName
propName propLabel/NIL propDesc/NIL
visible/NIL [dataType])
This functions create a new Property
propName inside
the PropertySet psetName
with optional label, description and
visibility state;
an optional preset data type for the property
can be specified.
Arguments
psetName (string) the name of the PropertySet where to create
the property;
if 'psetName' PropertySet does not exist yet,
it will be created with default parameters
propName (string) the name of the Property to be
created
propLabel (string or NIL) the GUI label for the Property; if
specified as empty string or NIL, the propName will be used
automatically
propDesc (string or NIL) the description for the Property; if
not provided (specified as NIL), then the description remains an
empty string
visible (T
or NIL) specifies whether the Property propName will be visible (T)
or hidden (NIL)
dataType (optional, integer or NIL) specifies the data
type for the new property;
supported data types are : bool, integer,
double, string (use bcBimTypeBool or
bcBimTypeInteger or bcBimTypeDouble
or bcBimTypeString), see
Property
DataType Constants
Return
T or NIL, indicating success
or failure
Example
(vl-load-bim)
(bim:create-propertyset "MyPerInstance-1"
"MyPSet-1" T T)
(bim:pset-create-property "MyPSet-1" "Prop-1"
"PropLabel-1" "PropDesc-1" T)
Remarks
the "visible" status means
whether the Property is visible in PropertiesPanel;
the psetName argument can refer to the
PropertySet 'name' or PropertySet 'label', both is supported
Note
if dataType is omitted or NIL,
the new property will be created with undefined property data
type (shown as "[Extended type]" in BimProperties
dialog);
the effective property data type is then
defined with the first assignment of a value by (bim:pset-set-property)
