bim:delete-propertysets
(bim:delete-propertysets [categoryId |
categoryName])
Arguments
(optional)
specifies the Category (as predefined integer
constant) or as
categoryId (integer) BIM property category ID to delete all
PropertsSets from, can be omitted (bcBimCategoryUser is used then);
see Category Constants
---or---
categoryName (string) BIM property category to delete all
PropertsSets from (can be an empty string for bcBimCategoryUser),
if omitted, the all PropertySets from any
category are deleted
Return
T or NIL, indicating success
or failure
Example
Remarks
the Category name/label is
case-insensitive
