civil:converter-attachedlabels
(civil:converter-attachedlabels
converter handle)
Returns the list of converted label entities,
attached to the specified alignment or surface C3D Entity
handle (integer);
only valid after (civil:converter-convert
converter) has been used !
Arguments |
converter (handle, integer) the converter object as
instantiated by (civil:get-converter) |
Return |
a list of ENAME, or NIL |
Example |
(vl-load-civil) |
Remarks |
for any other C3D entity type, NIL will be returned. |
