civil:converter-convert
(civil:converter-convert converter
[handles])
Converts (extracts) all C3D entities, or the
subset as specified by optional handles list (list of integer)
of native C3D entities.
Arguments
converter (handle, integer) the converter object as
instantiated by (civil:get-converter)
handles (list of integer handles, optional) if
provided, a list of integer handles for the C3D entities to be
converted; if omitted, all suitable C3D entities are
converted
Return
returns a list of 2 sub-lists
first list contains <handle . ename>
pairs for original + converted entities;
second list contains all other entities
created by conversion (can be NIL);
NIL is returned in case of an error, or if no
C3D entities are present, or could be converted
Example
(vl-load-civil)
(setq converter (civil:get-converter
255))
(setq c3dents
(civil:converter-get-c3d-entities converter)
(setq res (civil:converter-convert converter
c3dents)))
((<Entity name: a27a5a30> . 1852005136)
(<Entity name: a27a4130> . 1852004976) (<Entity name:
a27a5870> . 1852018880) (<Entity name: a27a50b0> .
1852006336) (<Entity name: a27a31f0> .
1852022720))
(<Entity name: a27af570> <Entity
name: a27af530> <Entity name: a27af930> <Entity name:
a27a5bf0> <Entity name: a27a70b0> <Entity name:
a27a4ef0>)
Remarks
