civil:converter-get-c3d-basealignment
(civil:converter-get-c3d-basealignment
handle)
Returns the base alignment definition for the
specified C3D Profile entity handle (integer).
Arguments |
handle (handle, integer) the C3D entity to retrieve the base alignment for |
Return |
the base alignment definition data (list, same as returned by (civil:converter-get-c3d-info) function) on success, or NIL if the specified handle does not refer to a C3D Profile entity |
Example |
(vl-load-civil) |
Remarks |
for the base alignment definition list, please see (civil:converter-get-c3d-info) |
