civil:pgroups-set-lastusedpointnumber
(civil:pgroups-set-lastusedpointnumber
number)
Defines the "last-used point"
number which is
used for numbering newly created C3D Point entities.
Arguments |
number (integer >= 0) the new "last-used point number" to be used |
Return |
T or NIL in case of an error |
Example |
(vl-load-civil)
T (setq res (civil:pgroups-get-lastusedpointnumber)) 100 |
Remarks |
