key, string identifier of a DCL tile
as it appears in the DCL file
argument 2:
integer mode 0-4
return value:
nil
description:
The behaviour of this function depends
on the integer mode argument.
These are the possible modes with their effect:
0: Enable the specified tile (stop "grayed out" effect).
1: Disable the specified tile (tile becomes "grayed out").
2: Set the focus to the specified tile.
3: This mode applies to an edit_box tile only. Select the
content of the edit_box.
4: This mode applies only to an image or image_button tile.
Flip the highlighting of the image or image_button: highlight if it
was not highlighted before and vice versa. If an image or
image_button is highlighted, a colored border surrounds it and its
colors are inverted.
When enabling or disabling a cluster tile (by mode argument 0 or 1),
all of its children will be enabled or disabled respectively. See
also the is_enabled
attribute about enabling/disabling.
