mech:compdef-get-standardpartdescription
(mech:compdef-get-standardpartdescription  blkRefOrSolid  localisedName)
Returns the description of the standard part of the component, referenced by the blkRefOrSolid (ename) entity.
Arguments
blkRefOrSolid (ename) the entity to query
localisedName  T/NIL  defines whether the localised (T) or the global (NIL) English description shall be returned
Return
global resp. localised description of the standard part (string), or NIL if not a "standard part" (and in case of an error)
Example
(vl-load-mech)  1
(setq blkRefOrSolid (entlast))
<Entity name: 7dabeda0>
(setq res (mech:compdef-get-standardpartdescription blkRefOrSolid T))
"HEX NUT, PLAIN"
Remarks
blkRefOrSolid could be a BlockReference or 3dSolid
Note
see function (mech:compdef-get-isstandard)
©  Bricsys NV. All rights reserved.
