mech:compdef-set-custompropertyvalue
(mech:compdef-set-custompropertyvalue  blkRefOrSolid  category  property  value)
Assigns a new value for the property name contained in PropertySet category for the blkRefOrSolid (ename) entity.
Arguments
blkRefOrSolid (ename) the entity
category (string) the Category/PropertySet containing the name property
property (string) the name of the property to be changed
value (integer/double/string/T/NIL) value to be assigned
Return
T on success, or NIL in case of an error
Example
(vl-load-mech)  1
(setq blkRefOrSolid (entlast))
<Entity name: 7e4ddcf0>
(setq res (mech:compdef-get-custompropertyvalue blkRefOrSolid "Test" "TestProp"))
("Test" "TestProp" "zzz" "zzz")
(setq res (mech:compdef-set-custompropertyvalue blkRefOrSolid "Test" "TestProp" "0000"))
T
("Test" "TestProp" "0000" "0000")
Remarks
blkRefOrSolid could be a BlockReference or 3dSolid
Note
1. the Category/PropertySet category must already exist
2. if the property does not exist yet, it is automatically created inside the category PropertySet
to create and assign a new CategoryPropertySet, see function (mech:compdef-assign-propertyset)
©  Bricsys NV. All rights reserved.
