param:constraint-get-isdimensional
(param:constraint-get-isdimensional  constraint)
Returns whether the specified constraint (integer) is dimensional or not.
Arguments
constraint (integer) the constraint to query
Return
T or NIL
Example
(vl-load-mech)  2
(setq blkId (tblobjname "BLOCK" "*Model_Space"))  <Entity name: a44cefc0>
(setq grp (mech:get-constraintsgroup blkId))  2684693328
(setq constraints (mech:get-constraints grp))  (2684692368)
(setq constraint (nth 0 constraints))  2684692368
(setq isDim (mech:constraint-get-isdimensional constraint))  NIL
Remarks
Note
©  Bricsys NV. All rights reserved.
