param:has-sketchplane
(param:has-sketchplane
constraintsGroup)
Verifies whether the constraintsGroup (integer)
uses a 'Sketch Plane' or not.
Arguments |
constraintsGroup (integer) the constraints group to query for the 'Sketch Plane' status |
Return |
T if a 'Sketch Plane' is used, or NIL otherwise |
Example |
(vl-load-mech)
2 |
Remarks |
see functions (param:get-allconstraintsgroups) and (param:get-constraintsgroup) to retrieve the constraintsGroup |
Note |
