tinc:setmidordinatedistance
(tinc:setMidOrdinateDistance ename
constraint dist)
This function assigns the mid-ordinate-distance dist for the
constraint for
the ename TinSurface entity.
Arguments |
ename (ename) the TinSurface entity to
query |
Return |
T or NIL |
Example |
(tinc:setmidordinatedistance tin constraint 0.1) T |
Remarks |
the mid-ordinate distance is the
distance of the curve's midpoint, to the arc center; similar to
arc's bulge; used as a kind of tolerance; |
