vl-subent-select
(vl-subent-select [ msg ] [
subentTypes [ osmode ]])
Queries the user by optional
msg (string)
prompt message to select a point using the optional object snap
mode osmode (integer, default 591,
end+mid+center+node+insertion+nearest) to return the subentity
definition list of the entity/subentity found at selected point,
and filtered by subentTypes
(integer bit flags);
returns list (point <subent-definition>
<subent-definition> ... <subent-definition>) or
NIL
Arguments |
msg (string, optional) the prompt message to be
shown; if omitted, "Select entity:" is shown |
Return |
list (selectionpoint <subent-definition> <subent-definition> ... <subent-definition>), or NIL |
Example |
(setq sel
(vl-subent-select)) |
Remarks |
SubEntity selection constants
<subent-definition> |
list of subentity type,
subentity index (GsMarker), main entity |
