Works with Classic, Pro
Sets selection area for snapping to entities.
command bar: aperture
transparent: 'aperture
alias: ap
menu bar: Settings | Entity Snap Precision
toolbar: Settings |
: aperture
Selection area for entity snap (1-50 pixels) <10>: (Enter a value between 1 and 50, or press Enter to keep the default value.)
The aperture cursor works in conjunction with entity snaps. Bricscad searches the area inside the aperture cursor for entity features, such as endpoints and mid points.
A larger aperture cursor finds entity features more easily but can be too imprecise; a smaller one is more precise but can make it harder to find entity features.
By default, the aperture cursor is turned off. Use the ApBox system variable to turn it on.
Changes the size of the aperture cursor; range is from 1 to 50 pixels wide. |
OSnap - toggles entity snap modes in the Settings dialog box.
-OSnap - toggles entity snap modes in the command bar.
