Works with Classic, Pro
Sets entity snaps through the Settings dialog box (short for "object snap").
command bar: osnap
transparent: 'osnap
shortcut: F8
alias: ddosnap, ddesnap, os, setesnap
menu bar: Settings | Entity Snap Settings
toolbar: Settings | ![]()
status bar: ESNAP
: osnap
Displays the Entity Snaps section of the Settings dialog box:
Change a setting, and then click X.
Toggles endpoint entity snap mode. Snaps to the end points of open entities, such as lines,arcs, open polylines,and open splines.
Can also be toggled with the Endpoint command. |
Toggles midpoint entity snap mode. Snaps to the midpoint of open entities.
Can also be toggled with the Midpoint command. |
Toggles center entity snap mode. Snaps to the center of circular entities, such as circles, arcs, and polyarcs.
Can also be toggled with the Center command. |
Toggles node entity snap mode. Snaps to point entities.
Can also be toggled with the Node command. |
Toggles quadrant entity snap mode. Snaps to the quadrants points of circular entities, such as circles, arcs, and polyarcs.
Can also be toggled with the Quadrant command. |
Toggles intersection entity snap mode. Snaps to the intersection of any pair of entities.
Can also be toggled with the Intersection command. |
Toggles insertion entity snap mode. Snaps to the insertion point of blocks and text.
Can also be toggled with the Insertion command. |
Toggles perpendicular entity snap mode. Snaps to the perpendicular of one entity to another.
Can also be toggled with the Perpendicular command. |
Toggles Tangent entity snap mode. Snaps to the tangencies of circular entities.
Can also be toggled with the Tangent command. |
Toggles nearest entity snap mode. Snaps to the nearest point on any entity.
Can also be toggled with the Nearest command. |
Toggles quick entity snap mode. Snaps to the first geometric feature of entities.
Can also be toggled with the Quick command. |
Toggles Apparent entity snap mode. Snaps to the apparent intersection of entities in 3D space.
Can also be toggled with the Apparent command. |
Toggles extension entity snap mode. Snaps to the intersection of open entities, as if they were extended to the point of intersection.
Can also be toggled with the Extension command. |
(Not implemented) |
Toggles parallel entity snap mode. Snaps to the parallel point of entities. This mode is not yet implemented. |
Turns all entity snap modes off. Modes can also be turned off with the None command. |
Right-click ESNAP on the status bar for the shortcut menu:
Shortcut Menu |
On |
Turns on entity snaps. |
Off |
Turns off entity snaps. |
Settings |
Opens the Entity Snaps section of the Settings dialog box. |
-OSnap - toggles entity snap modes in the command bar.
Aperture - sizes the aperture cursor for entity snaps.
2dIntersection - toggles apparent intersection snap mode.
3dIntersection - toggles intersection snap mode.
Apparent - toggles apparent intersection snap mode.
Center - toggles center snap mode.
Endpoint - toggles endpoint snap mode.
Extension - toggles extension snap mode.
Insertion - toggles insertion snap mode.
Midpoint - toggles midpoint snap mode.
Nearest - toggles nearest snap mode.
Node - toggles node (point) snap mode.
None - turns off all entity snap modes.
Perpendicular - toggles perpendicular snap mode.
Quadrant - toggles quadrant snap mode.
Quick - toggles quick snap mode.
Tangent - toggles tangent snap mode.
