Specify the maximum value of a slider.
This attribute specifies the maximum value that a slider tile returns.
int: a 32-bit integer; default = 10000 and maximum = 2,147,483,647.
Example
NOTE Horizontal sliders increase in value from left to right; vertical sliders increase in value from top to bottom.
The big_increment and small_increment attributes specify how much the slider increments when the user clicks the slider.
Valid Tile
Tell me about...
Programming Overview of DCL (Dialog Control Language)
