Display a horizontal or vertical slider. DCL Active Tile
This active tile displays a slider bar, which can be horizontal or vertical. The slider moves faster or slower depending on where the user clicks.
Valid Attributes
Example
NOTE The value attribute indicates the default value of the slider bar; the default is min_value.
Related DCL Tiles
Tell me about...
Programming Overview of DCL (Dialog Control Language)
