Specify the minimum value of a slider.
This attribute specifies the minimum value that a slider tile returns.
int: a 32-bit integer; default = 0 and minimum = -2,147,483,648.
Example
NOTE Horizontal sliders increase in value from left to right; vertical sliders increase value from top to bottom.
The big_increment and small_increment attributes specify how much the slider increments when the user clicks on slider.
Valid Tile
Tell me about...
Programming Overview of DCL (Dialog Control Language)
