The two aren't equal.
This function tells you if two items are not equal:
When more than two items are given, each item must be different to return a T. The items can be numbers or strings.
Examples
| This expression | Returns |
| (/= 5 4) | T |
| (/= 8.0 8) | nil |
| (/= "x" "x" "x") | nil |
| (/= "x" "x" "y") | nil |
| (/= "x" "y" "z") | T |
| (/= 5) | T |
NOTE Comparison statements (such as = (equal to operator) and < (less than operator) are typically used together with conditional statements, such as if...then, while, and cond. The comparisons let you test a pair of conditions (for example, does i= 0) to know when to exit the conditional (for example, while i > 0).
Tell me about...
(if test statement1 [statement2])
Programming Overview of LISP (LISt Processing) Language
