Change this angle to a real number.
This function converts a string that contains an angle to a real number in radian format. The optional mode specifies the format of the "number" in the string:
| Mode value | String format |
| 0 | Decimal degrees |
| 1 | Degrees-minutes-seconds |
| 2 | Grad |
| 3 | Radian |
| 4 | Surveyor's units |
NOTE This command fails if the text of the string is not recognizable as an angle measurement.
Examples
| Code | Returns |
| (angtof "90") | 1.57080 |
| (angtof "90" 0) | 1.57080 |
| (angtof "90d30'10\"") | 1.57957 |
NOTES
Tell me about...
(rtos number [mode [precision]])
Programming Overview of LISP (LISt Processing) Language
