Find the first matching item in the list.
This function finds and returns the first sublist in list whose first element matches the association item. The list may contain dotted pairs from the cons and entget functions.
Examples
| Code | Returns |
| (setq bigl '((a b c)(d)(e f g))) (assoc 'e bigl) |
(E F G) |
| (setq elist (entget (car (entsel "Select entity:")))) (princ (strcat "\nYou selected a " (cdr (assoc 0 elist)))) |
NOTE This function is often used in conjunction with the dotted pairs returned by the cons and entget functions.
Tell me about...
(mapcar function list1 [list2 ...])
Programming Overview of LISP (LISt Processing) Language
