(autoload application list)
Automatically load the LISP application when one of its commands is used.
This function returns associates a list of command names with an application name. Then, when the user types a command name, Bricscad searches for and loads the associated LSP file.
Example
Code Returns
(autoload "routine" '("start" "run" "stop")) nil
Tell me about...
(autoxload application list)
(load filename [flag])
LISP Compatibility
Programming Overview of LISP (LISt Processing) Language
