Determine the y-dimension of a dialog box tile.
This function, together with dimx_tile function, returns the dimensions of the tile with the name key. The x,y dimensions are typically used by other dialog box functions, such as vector_image.
Example
| Code | Returns |
| (dimx_tile "pickbox_image") | 20 |
| (dimy_tile "pickbox_image") | 15 |
NOTES
Tell me about...
(fill_image x y width height color)
(slide_image x y width height slide)
Programming Overview of LISP (LISt Processing) Language
