Display the status of the LISP memory.
This function reports on the status of the memory being used by LISP. The parameters reported by mem have the following meanings:
| mem | Meaning |
| Nodes | Total number of nodes allocated to LISP. |
| Free nodes | Number of nodes freed by garbage collection. |
| Segments | Number of segments allocated. |
| Allocate | Size of the segment. |
| Collections | Number of garbage collections. |
Example
| Code | Returns |
| (mem) |
Nodes: 33934 Free nodes: 1744 Segments: 40 Allocate: 514 Collections: 24 |
NOTE A node is 12 bytes.
The default size of a segment is 514 nodes. Use the alloc function to change the size of the segment. Use the expand function to change the number of segments.
Tell me about...
Programming Overview of LISP (LISt Processing) Language
