(minusp number)
Determine whether a value is a negative number.
This function determines negative numbers. If number is an integer or a real number and it has a negative value, the minusp function returns a T. Otherwise it returns a nil.
Examples
Code Returns
(minusp -2.4) T
(minusp 8.5) nil
(minusp -26) T
Tell me about...
(listp item)
(numberp item)
LISP Compatibility
Programming Overview of LISP (LISt Processing) Language
