(xdsize list)
Determine how much space a list takes up as xdata.
This function returns the size (in bytes) that a list occupies as extended entity data. The list argument is a list of extended data that contain an application name registered with the regapp function. When the application name is unregistered, Bricscad displays the error message, "Invalid application name in 1001 group nil."
Example
Code Returns
(xdsize lst) 38
NOTE  An invalid list creates an error message that is stored via an error code in system variable ERRNO.
Tell me about...
(xdroom entity-name)
LISP Compatibility
Programming Overview of LISP (LISt Processing) Language
