Load that SDS application.
This function loads the SDS application (a DLL file) specified by appname. Once the application is loaded, you have access to all the commands it registers.
The optional flag argument is only used when an error occurs during loading. The xload function returns the value of this flag upon failure; when flag is missing, an error message is displayed instead.
When the application you are attempting to xload is already loaded, you see a message to that effect. It will not be loaded a second time.
Examples
| Code | Returns |
| (xload "goodapp") | Loads the application "goodapp". |
| (xload "badapp") |
Error loading application: Could not find badapp.dll. |
| (xload "badapp" "Uh-oh!") |
Error loading application: Could not find badapp.dll. "Uh-oh!" |
| (xload "badapp" (xload "goodapp")) |
Loads the application "goodapp". Error loading application: Could not find badapp.dll |
| (xload "loadedapp") |
Application "C:loadedapp.dll" is already loaded. |
Can't open "loadedapp" for execution. error: XLOAD failed *Cancel* "loadedapp" |
Tell me about...
Programming Overview of LISP (LISt Processing) Language
