Following functions -which are not part of standard AutoLISP®- also are available in Bricscad.
(get_diskserialid)
returns a 9-digit unique id string, based on the 1. hard disk serial number;
if the hard disk serial number can not be obtained in very rare caes, the
9-digit unique id string is based on the serial number of the 1. partition;
this id string provides a licensing/hardlocking feature for Lisp applications
(acos x)
Returns the arc cosine of x.
(cosh x)
Returns the hyperbolc cosine of x.
(asin x)
Returns the arc sine of x.
(sinh x)
Returns the hyperbolc sine of x.
(atanh x)
Returns the hyperbolic arc tangent of x.
(ceiling x)
Returns the smallest integer that is not smaller than x.
(find item list)
Returns item if item is found in list, otherwise it returns nil.
(floor x)
Returns the greatest integer less than or equal to x.
(getpid)
Returns the process ID of the current process.
(log10 x)
Returns the base-10 logarithm of x.
(position item list)
Returns the index ot item in list or nil (first index is 0)
(remove item list)
Returns the input list, with item removed from the list.
(round x)
Returns the integer nearest to x.
(search list1 list2)
Searches for list1 in list2 and returns the index where found or nil
(first index is 0)
(sleep millisecs)
Delays execution for (approx.) given milliseconds
(string-split string-of-delimiters string)
Returns a list of strings divided by any character in string-of-delimiters.
Example :
(string-split " ,;" "aaa bbb;ccc,ddd") => ("aaa" "bbb" "ccc" "ddd")
(tan x)
Returns the tangent of x - x must be in radians.
(tanh x)
Returns the hyperbolc tangent of x.
(until test-expression [expression ... ])
Repeats the expression(s) until test-expression evaluates as T (true).
(vla-collection->list <collection-object>)
this returns a collection as a normal LISP list
(acet-sys-control-down)
(acet-sys-shift-down)
(acet-sys-lmouse-down)
(acet-sys-mmouse-down)
(acet-sys-rmouse-down)
(acet-ui-progress-init title maxstep)
(acet-ui-progress-safe pos)
(acet-ui-progress-done)
(acet-autoload <filelist>)
(acet-autoload2 <filelist>)
(acet-autoloadarx <filelist>)
vl-load-com
vl-load-reactors
vl-list-loaded-vlx
vl-unload-vlx
vl-vlx-loaded-p
Lisp-Engine additionally provides the following LISP functions
vlr-command-reactor
vlr-editor-reactor
vlr-mouse-reactor
vlr-lisp-reactor
vlr-dwg-reactor
vlr-dxf-reactor
vlr-miscellaneous-reactor
vlr-deepclone-reactor
vlr-sysvar-reactor
vlr-window-reactor
vlr-toolbar-reactor
vlr-insert-reactor
vlr-wblock-reactor
vlr-undo-reactor
vlr-docmanager-reactor
vlr-linker-reactor
vlr-xref-reactor
vlr-object-reactor
vlr-acdb-reactor
vlr-pers
vlr-pers-list
vlr-pers-p
vlr-pers-release
vlr-add
vlr-added-p
vlr-beep-reaction
vlr-current-reaction-name
vlr-data
vlr-data-set
vlr-notification
vlr-owners
vlr-owner-add
vlr-owner-remove
vlr-reactions
vlr-reactors
vlr-reaction-set
vlr-reaction-names
vlr-remove
vlr-remove-all
vlr-set-notification
vlr-trace-reaction
vlr-type
vlr-types
vla-get-isquiescent
vla-get-version
vla-get-caption
vla-get-localeid
vla-get-hwnd
vla-get-windowstate
vla-get-windowleft
vla-get-windowtop
vla-get-active
vla-get-activedocument
vla-get-activespace
vla-get-activelayout
vla-get-activelayer
vla-get-activelinetype
vla-get-activetextstyle
vla-get-activedimstyle
vla-get-activeucs
vla-get-activeviewport
vla-get-activepviewport
vla-get-activeselectionset
vla-get-activeprofile
vla-get-activematerial
vla-get-statusid
vla-get-saved
vla-get-readonly
vla-get-name
vla-get-categoryname
vla-get-layoutid
vla-get-layerstate
vla-get-hasvpassociation
vla-get-fullname
vla-get-description
vla-get-WindowTitle
vla-get-path
vla-get-handle
vla-get-objectname
vla-get-ownerid
vla-get-objectid
vla-get-parent
vla-objectidtoobject
vla-handletoobject
vla-get-database
vla-get-xrefdatabase
vla-get-application
vla-get-document
vla-get-hasextensiondictionary
vla-get-modelspace
vla-get-paperspace
vla-get-mspace
vla-get-activespace
vla-get-layout
vla-get-utility
vla-get-documents
vla-get-layers
vla-get-blocks
vla-get-textstyles
vla-get-linetypes
vla-get-views
vla-get-usercoordinatesystems
vla-get-viewports
vla-get-dimstyles
vla-get-registeredapplications
vla-get-dictionaries
vla-get-layouts
vla-get-groups
vla-get-plotconfigurations
vla-get-plot
vla-get-filedependencies
vla-get-summaryinfo
vla-get-sectionmanager
vla-get-materials
vla-get-vbe
vla-get-preferences
vla-get-profiles
vla-get-selectionsets
vla-get-pickfirstselectionset
vla-get-files
vla-get-display
vla-get-OpenSave
vla-get-Output
vla-get-System
vla-get-User
vla-get-Drafting
vla-get-Selection
vla-get-Profiles
vla-get-menubar
vla-get-menugroups
vla-get-toolbars
vla-get-menus
vla-get-menufile
vla-get-menufilename
vla-get-largebuttons
vla-get-dockstatus
vla-get-left
vla-get-top
vla-get-floatingrows
vla-get-count
vla-get-closed
vla-get-color
vla-get-freeze
vla-get-layeron
vla-get-lock
vla-get-used
vla-get-viewportdefault
vla-get-truecolor
vla-get-layer
vla-get-linetype
vla-get-lineweight
vla-get-linetypescale
vla-get-linetypegeneration
vla-get-visible
vla-get-plotstylename
vla-get-position
vla-get-center
vla-get-radius
vla-get-diameter
vla-get-circumference
vla-get-totalangle
vla-get-arclength
vla-get-area
vla-get-material
vla-get-thickness
vla-get-length
vla-get-delta
vla-get-hyperlinks
vla-get-limits
vla-get-plottable
vla-get-origin
vla-get-height
vla-get-lastheight
vla-get-width
vla-get-insertionpoint
vla-get-rotation
vla-get-scalefactor
vla-get-obliqueangle
vla-get-stylename
vla-get-textstring
vla-get-alignment
vla-get-attachmentpoint
vla-get-drawingdirection
vla-get-linespacingfactor
vla-get-linespacingstyle
vla-get-linespacingdistance
vla-get-backgroundfill
vla-get-textgenerationflag
vla-get-upsidedown
vla-get-backward
vla-get-promptstring
vla-get-tagstring
vla-get-fieldlength
vla-get-mode
vla-get-invisible
vla-get-constant
vla-get-verify
vla-get-preset
vla-get-lockposition
vla-get-type
vla-get-annotation
vla-get-coordinates
vla-get-startpoint
vla-get-endpoint
vla-get-startangle
vla-get-endangle
vla-get-majorradius
vla-get-minorradius
vla-get-radiusratio
vla-get-startparameter
vla-get-endparameter
vla-get-angle
vla-get-coordinate
vla-get-textcolor
vla-get-textposition
vla-get-textrotation
vla-get-textalignmentpoint
vla-get-textgap
vla-get-textfont
vla-get-bigfontfile
vla-get-fontfile
vla-get-textfontsize
vla-get-textfontstyle
vla-get-textprefix
vla-get-textsuffix
vla-get-decimalseparator
vla-get-visibilityedge1
vla-get-visibilityedge2
vla-get-visibilityedge3
vla-get-visibilityedge4
vla-get-numberofvertices
vla-get-numberoffaces
vla-get-mclose
vla-get-nclose
vla-get-mdensity
vla-get-ndensity
vla-get-mvertexcount
vla-get-nvertexcount
vla-get-justification
vla-get-mlinescale
vla-get-hasattributes
vla-get-effectivename
vla-get-isdynamicblock
vla-get-propertyname
vla-get-show
vla-get-allowedvalues
vla-get-value
vla-get-unitstype
vla-get-iscloned
vla-get-isownerxlated
vla-get-isprimary
vla-get-key
vla-get-scalewidth
vla-get-scaleheight
vla-get-lockaspectratio
vla-get-oleitemtype
vla-get-oleplotquality
vla-get-olesourceapp
vla-get-comments
vla-get-units
vla-get-explodable
vla-get-blockscaling
vla-get-columns
vla-get-columnspacing
vla-get-rows
vla-get-rowspacing
vla-get-translateids
vla-get-mask
vla-get-shadowdisplay
vla-get-brightness
vla-get-contrast
vla-get-fade
vla-get-transparency
vla-get-imagewidth
vla-get-imageheight
vla-get-imagefile
vla-get-imagevisibility
vla-get-clippingenabled
vla-get-showrotation
vla-get-measurement
vla-get-tolerancejustification
vla-get-tolerancedisplay
vla-get-textmovement
vla-get-textoverride
vla-get-textstyle
vla-get-textheight
vla-get-horizontaltextposition
vla-get-verticaltextposition
vla-get-suppresszerofeet
vla-get-suppresszeroinches
vla-get-arrowheadsize
vla-get-arrowheadtype
vla-get-arrowheadblock
vla-get-arrowhead1type
vla-get-arrowhead1block
vla-get-arrowhead2type
vla-get-arrowhead2block
vla-get-arcpoint
vla-get-centerpoint
vla-get-leader1point
vla-get-leader2point
vla-get-ispartial
vla-get-arcstartparam
vla-get-arcendparam
vla-get-hasleader
vla-get-symbolposition
vla-get-textprecision
vla-get-dimlineinside
vla-get-forcelineinside
vla-get-textinside
vla-get-textinsidealign
vla-get-textoutsidealign
vla-get-dimensionlinecolor
vla-get-dimensionlineweight
vla-get-dimensionlinetype
vla-get-dimensionlineextend
vla-get-extensionlinecolor
vla-get-extensionlineweight
vla-get-extensionlineextend
vla-get-extensionlineoffset
vla-get-dimlinesuppress
vla-get-dimline1suppress
vla-get-dimline2suppress
vla-get-extline1suppress
vla-get-extline2suppress
vla-get-fit
vla-get-unitsformat
vla-get-linearscalefactor
vla-get-rounddistance
vla-get-extline1point
vla-get-extline2point
vla-get-extline1startpoint
vla-get-extline2startpoint
vla-get-extline1endpoint
vla-get-extline2endpoint
vla-get-extline1linetype
vla-get-extline2linetype
vla-get-extlinefixedlensuppress
vla-get-textfill
vla-get-textfillcolor
vla-get-angleformat
vla-get-anglevertex
vla-get-tolerancesuppresszerofeet
vla-get-tolerancesuppresszeroinches
vla-get-toleranceprecision
vla-get-toleranceheightscale
vla-get-tolerancelowerlimit
vla-get-toleranceupperlimit
vla-get-centertype
vla-get-centermarksize
vla-get-suppressleadingzeros
vla-get-suppresstrailingzeros
vla-get-tolerancesuppressleadingzeros
vla-get-tolerancesuppresstrailingzeros
vla-get-primaryunitsprecision
vla-get-fractionformat
vla-get-altunits
vla-get-altunitsprecision
vla-get-altunitsscale
vla-get-altunitsformat
vla-get-altrounddistance
vla-get-alttextprefix
vla-get-alttextsuffix
vla-get-alttoleranceprecision
vla-get-altsuppressleadingzeros
vla-get-altsuppresstrailingzeros
vla-get-altsuppresszerofeet
vla-get-altsuppresszeroinches
vla-get-alttolerancesuppressleadingzeros
vla-get-alttolerancesuppresstrailingzeros
vla-get-alttolerancesuppresszerofeet
vla-get-alttolerancesuppresszeroinches
vla-get-overridecenter
vla-get-joglocation
vla-get-jogangle
vla-get-chordpoint
vla-get-lowerleftcorner
vla-get-upperrightcorner
vla-get-orthoon
vla-get-gridon
vla-get-viewporton
vla-get-displaylocked
vla-get-standardscale
vla-get-customscale
vla-get-xscalefactor
vla-get-yscalefactor
vla-get-zscalefactor
vla-get-xeffectivescalefactor
vla-get-yeffectivescalefactor
vla-get-zeffectivescalefactor
vla-get-insunits
vla-get-insunitsfactor
vla-get-direction
vla-get-xvector
vla-get-yvector
vla-get-directionvector
vla-get-volume
vla-get-momentofinertia
vla-get-principaldirections
vla-get-principalmoments
vla-get-productofinertia
vla-get-radiiofgyration
vla-get-perimeter
vla-get-solidtype
vla-get-url
vla-get-urldescription
vla-get-basepoint
vla-get-secondpoint
vla-get-normal
vla-get-elevation
vla-get-elevationmodelspace
vla-get-elevationpaperspace
vla-get-objectsnapmode
vla-get-snapbasepoint
vla-get-snaprotationangle
vla-get-snapon
vla-get-ucsiconon
vla-get-ucsiconatorigin
vla-get-twistangle
vla-get-lenslength
vla-get-target
vla-get-arcsmoothness
vla-get-shadeplot
vla-get-clipped
vla-get-ucsperviewport
vla-get-modelview
vla-get-sheetview
vla-get-labelblockid
vla-get-hassheetview
vla-get-label
vla-get-enable
vla-get-check
vla-get-macro
vla-get-flyout
vla-get-submenu
vla-get-index
vla-get-helpstring
vla-get-endsubmenulevel
vla-get-namenomnemonic
vla-get-shortcutmenu
vla-get-onmenubar
vla-get-constantwidth
vla-get-centroid
vla-get-modeltype
vla-get-block
vla-get-taborder
vla-get-canonicalmedianame
vla-get-configname
vla-get-paperunits
vla-get-plotviewportborders
vla-get-plottype
vla-get-viewtoplot
vla-get-plothidden
vla-get-centerplot
vla-get-plotrotation
vla-get-showplotstyles
vla-get-scalelineweights
vla-get-plotwithlineweights
vla-get-plotviewportsfirst
vla-get-stylesheet
vla-get-plotorigin
vla-get-plotwithplotstyles
vla-get-isplanar
vla-get-isperiodic
vla-get-isrational
vla-get-degree
vla-get-numberofcontrolpoints
vla-get-numberoffitpoints
vla-get-controlpoints
vla-get-fitpoints
vla-get-knots
vla-get-weights
vla-get-starttangent
vla-get-endtangent
vla-get-fittolerance
vla-get-numberofloops
vla-get-patterntype
vla-get-patternname
vla-get-patternangle
vla-get-patternscale
vla-get-patternspace
vla-get-isopenwidth
vla-get-patterndouble
vla-get-associativehatch
vla-get-hatchstyle
vla-get-hatchobjecttype
vla-get-gradientcolor1
vla-get-gradientcolor2
vla-get-gradientangle
vla-get-gradientcentered
vla-get-gradientname
vla-get-entitycolor
vla-get-colorname
vla-get-bookname
vla-get-red
vla-get-blue
vla-get-green
vla-get-colormethod
vla-get-colorindex
vla-get-author
vla-get-hyperlinkbase
vla-get-keywords
vla-get-lastsavedby
vla-get-revisionnumber
vla-get-subject
vla-get-title
vla-get-action
vla-get-password
vla-get-providertype
vla-get-providername
vla-get-algorithm
vla-get-keylength
vla-get-issuer
vla-get-serialnumber
vla-get-comment"
vla-get-timeserver
vla-get-bitflags
vla-get-flowdirection
vla-get-horzcellmargin
vla-get-vertcellmargin
vla-get-titlesuppressed
vla-get-headersuppressed
vla-get-minimumtablewidth
vla-get-minimumtableheight
vla-get-tablestyleoverrides
vla-get-hassubselection
vla-get-regeneratetablesuppressed
vla-get-plotlegacy
vla-get-quieterrormode
vla-get-numberofcopies
vla-get-batchplotprogress
vla-get-supportpath
vla-get-driverspath
vla-get-helpfilepath
vla-get-defaultinterneturl
vla-get-configfile
vla-get-texteditor
vla-get-maindictionary
vla-get-customdictionary
vla-get-altfontfile
vla-get-fontfilemap
vla-get-printfile
vla-get-printspoolexecutable
vla-get-postscriptprologfile
vla-get-printspoolerpath
vla-get-autosavepath
vla-get-templatedwgpath
vla-get-logfilepath
vla-get-tempfilepath
vla-get-tempxrefpath
vla-get-texturemappath
vla-get-alttabletmenufile
vla-get-printerconfigpath
vla-get-printerdescpath
vla-get-printerstylesheetpath
vla-get-workspacepath
vla-get-colorbookpath
vla-get-toolpalettepath
vla-get-qnewtemplatefile
vla-get-plotlogfilepath
vla-get-pagesetupoverridestemplatefile
vla-get-projectfilepath
vla-get-enterprisemenufile
vla-get-customiconpath
vla-get-layoutdisplaymargins
vla-get-layoutdisplaypaper
vla-get-layoutdisplaypapershadow
vla-get-layoutshowplotsetup
vla-get-layoutcreateviewpor
vla-get-displayscrollbars
vla-get-displayscreenmenu
vla-get-cursorsize
vla-get-dockedvisiblelines
vla-get-showrasterimage
vla-get-graphicswinlayoutbackgrndcolor
vla-get-graphicswinmodelbackgrndcolor
vla-get-textwinbackgrndcolor
vla-get-textwintextcolor
vla-get-autotrackingveccolor
vla-get-layoutcrosshaircolor
vla-get-modelcrosshaircolor
vla-get-historylines
vla-get-maxautocadwindow
vla-get-displaylayouttabs
vla-get-imageframehighlight
vla-get-truecolorimages
vla-get-xreffadeintensity
vla-get-savepreviewthumbnail
vla-get-incrementalsavepercent
vla-get-autosaveinterval
vla-get-createbackup
vla-get-fullcrcvalidation
vla-get-logfileon
vla-get-tempfileextension
vla-get-xrefdemandload
vla-get-demandloadarxapp
vla-get-proxyimage
vla-get-showproxydialogbox
vla-get-autoaudit
vla-get-saveastype
vla-get-mrunumber
vla-get-defaultoutputdevice
vla-get-printerspoolalert
vla-get-printerpapersizealert
vla-get-olequality
vla-get-uselastplotsettings
vla-get-plotpolicy
vla-get-defaultplotstyletable
vla-get-defaultplotstyleforobjects
vla-get-defaultplotstyleforlayer
vla-get-continuousplotlog
vla-get-automaticplotlog
vla-get-defaultplottofilepath
vla-get-singledocumentmode
vla-get-displayolescale
vla-get-storesqlindex
vla-get-tablesreadonly
vla-get-enablestartupdialog
vla-get-beeponerror
vla-get-showwarningmessages
vla-get-loadacadlspinalldocuments
vla-get-keyboardaccelerator
vla-get-keyboardpriority
vla-get-hyperlinkdisplaycursor
vla-get-hyperlinkdisplaytooltip
vla-get-adcinsertunitsdefaultsource
vla-get-adcinsertunitsdefaulttarget
vla-get-shortcutmenudisplay
vla-get-scmdefaultmode
vla-get-scmeditmode
vla-get-scmcommandmode
vla-get-scmtimemode
vla-get-scmtimevalue
vla-get-autosnapmarker
vla-get-autosnapmagnet
vla-get-autosnapaperture
vla-get-autosnapaperturesize
vla-get-autosnaptooltip
vla-get-autosnapmarkercolor
vla-get-autosnapmarkersize
vla-get-polartrackingvector
vla-get-fullscreentrackingvector
vla-get-autotracktooltip
vla-get-alignmentpointacquisition
vla-get-pickfirst
vla-get-pickadd
vla-get-pickdrag
vla-get-pickauto
vla-get-pickboxsize
vla-get-displaygrips
vla-get-displaygripswithinblocks
vla-get-gripcolorselected
vla-get-gripcolorunselected
vla-get-gripsize
vla-get-pickgroup
vla-get-solidfill
vla-get-xrefedit
vla-get-xreflayervisibility
vla-get-olelaunch
vla-get-allowlongsymbolnames
vla-get-objectsortbyselection
vla-get-objectsortbysnap
vla-get-objectsortbyredraws
vla-get-objectsortbyregens
vla-get-objectsortbyplotting
vla-get-objectsortbypsoutput
vla-get-contourlinespersurface
vla-get-displaysilhouette
vla-get-maxactiveviewports
vla-get-rendersmoothness
vla-get-segmentperpolyline
vla-get-textframedisplay
vla-get-lineweightdisplay
vla-put-windowstate
vla-put-windowleft
vla-put-windowtop
vla-put-activedocument
vla-put-activespace
vla-put-mspace
vla-put-activelayout
vla-put-activelayer
vla-put-activelinetype
vla-put-activetextstyle
vla-put-activedimstyle
vla-put-activeucs
vla-put-activeviewport
vla-put-activepviewport
vla-put-activeprofile
vla-put-activematerial
vla-put-closed
vla-put-color
vla-put-freeze
vla-put-layeron
vla-put-lock
vla-put-viewportdefault
vla-put-truecolor
vla-put-layer
vla-put-linetype
vla-put-lineweight
vla-put-linetypescale
vla-put-linetypegeneration
vla-put-visible
vla-put-plotstylename
vla-put-position
vla-put-center
vla-put-radius
vla-put-diameter
vla-put-circumference
vla-put-area
vla-put-material
vla-put-thickness
vla-put-constantwidth
vla-put-taborder
vla-put-canonicalmedianame
vla-put-configname
vla-put-paperunits
vla-put-plotviewportborders
vla-put-plottype
vla-put-viewtoplot
vla-put-plothidden
vla-put-centerplot
vla-put-plotrotation
vla-put-showplotstyles
vla-put-scalelineweights
vla-put-plotwithlineweights
vla-put-plotviewportsfirst
vla-put-stylesheet
vla-put-plotorigin
vla-put-plotwithplotstyles
vla-put-supportpath
vla-put-driverspath
vla-put-helpfilepath
vla-put-defaultinterneturl
vla-put-texteditor
vla-put-maindictionary
vla-put-customdictionary
vla-put-altfontfile
vla-put-fontfilemap
vla-put-printfile
vla-put-printspoolexecutable
vla-put-postscriptprologfile
vla-put-printspoolerpath
vla-put-autosavepath
vla-put-templatedwgpath
vla-put-logfilepath
vla-put-tempfilepath
vla-put-tempxrefpath
vla-put-texturemappath
vla-put-alttabletmenufile
vla-put-printerconfigpath
vla-put-printerdescpath
vla-put-printerstylesheetpath
vla-put-workspacepath
vla-put-colorbookpath
vla-put-toolpalettepath
vla-put-qnewtemplatefile
vla-put-plotlogfilepath
vla-put-pagesetupoverridestemplatefile
vla-put-enterprisemenufile
vla-put-customiconpath
vla-setprojectfilepath
vla-put-layoutdisplaymargins
vla-put-layoutdisplaypaper
vla-put-layoutdisplaypapershadow
vla-put-layoutshowplotsetup
vla-put-layoutcreateviewport
vla-put-displayscrollbars
vla-put-displayscreenmenu
vla-put-cursorsize
vla-put-dockedvisiblelines
vla-put-showrasterimage
vla-put-graphicswinlayoutbackgrndcolor
vla-put-graphicswinmodelbackgrndcolor
vla-put-textwinbackgrndcolor
vla-put-textwintextcolor
vla-put-autotrackingveccolor
vla-put-layoutcrosshaircolor
vla-put-modelcrosshaircolor
vla-put-historylines
vla-put-maxautocadwindow
vla-put-displaylayouttabs
vla-put-imageframehighlight
vla-put-truecolorimages
vla-put-xreffadeintensity
vla-put-savepreviewthumbnail
vla-put-incrementalsavepercent
vla-put-autosaveinterval
vla-put-createbackup
vla-put-fullcrcvalidation
vla-put-logfileon
vla-put-tempfileextension
vla-put-xrefdemandload
vla-put-demandloadarxapp
vla-put-proxyimage
vla-put-showproxydialogbox
vla-put-autoaudit
vla-put-saveastype
vla-put-mrunumber
vla-put-defaultoutputdevice
vla-put-printerspoolalert
vla-put-printerpapersizealert
vla-put-olequality
vla-put-uselastplotsettings
vla-put-plotpolicy
vla-put-defaultplotstyletable
vla-put-defaultplotstyleforobjects
vla-put-defaultplotstyleforlayer
vla-put-continuousplotlog
vla-put-automaticplotlog
vla-put-defaultplottofilepath
vla-put-singledocumentmode
vla-put-displayolescale
vla-put-storesqlindex
vla-put-tablesreadonly
vla-put-enablestartupdialog
vla-put-beeponerror
vla-put-showwarningmessages
vla-put-loadacadlspinalldocuments
vla-put-keyboardaccelerator
vla-put-keyboardpriority
vla-put-hyperlinkdisplaycursor
vla-put-hyperlinkdisplaytooltip
vla-put-adcinsertunitsdefaultsource
vla-put-adcinsertunitsdefaulttarget
vla-put-shortcutmenudisplay
vla-put-scmdefaultmode
vla-put-scmeditmode
vla-put-scmcommandmode
vla-put-scmtimemode
vla-put-scmtimevalue
vla-put-autosnapmarker
vla-put-autosnapmagnet
vla-put-autosnapaperture
vla-put-autosnapaperturesize
vla-put-autosnaptooltip
vla-put-autosnapmarkercolor
vla-put-autosnapmarkersize
vla-put-polartrackingvector
vla-put-fullscreentrackingvector
vla-put-autotracktooltip
vla-put-alignmentpointacquisition
vla-put-pickfirst
vla-put-pickadd
vla-put-pickdrag
vla-put-pickauto
vla-put-pickboxsize
vla-put-displaygrips
vla-put-displaygripswithinblocks
vla-put-gripcolorselected
vla-put-gripcolorunselected
vla-put-gripsize
vla-put-pickgroup
vla-put-solidfill
vla-put-xrefedit
vla-put-xreflayervisibility
vla-put-olelaunch
vla-put-allowlongsymbolnames
vla-put-objectsortbyselection
vla-put-objectsortbysnap
vla-put-objectsortbyredraws
vla-put-objectsortbyregens
vla-put-objectsortbyplotting
vla-put-objectsortbypsoutput
vla-put-contourlinespersurface
vla-put-displaysilhouette
vla-put-maxactiveviewports
vla-put-rendersmoothness
vla-put-segmentperpolyline
vla-put-textframedisplay
vla-put-lineweightdisplay
vla-put-limits
vla-put-plottable
vla-put-origin
vla-put-height
vla-put-lastheight
vla-put-width
vla-put-insertionpoint
vla-put-rotation
vla-put-scalefactor
vla-put-obliqueangle
vla-put-stylename
vla-put-textstring
vla-put-alignment
vla-put-attachmentpoint
vla-put-drawingdirection
vla-put-linespacingfactor
vla-put-linespacingstyle
vla-put-linespacingdistance
vla-put-backgroundfill
vla-put-url
vla-put-urldescription
vla-put-basepoint
vla-put-secondpoint
vla-put-textgenerationflag
vla-put-upsidedown
vla-put-backward
vla-put-promptstring
vla-put-tagstring
vla-put-fieldlength
vla-put-mode
vla-put-invisible
vla-put-constant
vla-put-verify
vla-put-preset
vla-put-lockposition
vla-put-type
vla-put-annotation
vla-put-coordinates
vla-put-startpoint
vla-put-endpoint
vla-put-startangle
vla-put-endangle
vla-put-majorradius
vla-put-minorradius
vla-put-radiusratio
vla-put-startparameter
vla-put-endparameter
vla-put-coordinate
vla-put-visibilityedge1
vla-put-visibilityedge2
vla-put-visibilityedge3
vla-put-visibilityedge4
vla-put-mclose
vla-put-nclose
vla-put-mdensity
vla-put-ndensity
vla-put-justification
vla-put-mlinescale
vla-put-controlpoints
vla-put-fitpoints
vla-put-knots
vla-put-weights
vla-put-starttangent
vla-put-endtangent
vla-put-fittolerance
vla-put-patternangle
vla-put-patternscale
vla-put-patternspace
vla-put-isopenwidth
vla-put-patterndouble
vla-put-associativehatch
vla-put-hatchstyle
vla-put-hatchobjecttype
vla-put-gradientcolor1
vla-put-gradientcolor2
vla-put-gradientangle
vla-put-gradientcentered
vla-put-gradientname
vla-put-entitycolor
vla-put-colormethod
vla-put-colorindex
vla-put-author
vla-put-hyperlinkbase
vla-put-keywords
vla-put-lastsavedby
vla-put-revisionnumber
vla-put-subject
vla-put-title
vla-put-action
vla-put-password
vla-put-providertype
vla-put-providername
vla-put-algorithm
vla-put-keylength
vla-put-issuer
vla-put-serialnumber
vla-put-comment"
vla-put-timeserver
vla-put-bitflags
vla-put-flowdirection
vla-put-horzcellmargin
vla-put-vertcellmargin
vla-put-titlesuppressed
vla-put-headersuppressed
vla-put-columnwidth
vla-put-rowheight
vla-put-regeneratetablesuppressed
vla-put-plotlegacy
vla-put-quieterrormode
vla-put-numberofcopies
vla-put-batchplotprogress
vla-put-brightness
vla-put-contrast
vla-put-fade obj
vla-put-transparency
vla-put-imagewidth
vla-put-imageheight
vla-put-imagefile
vla-put-imagevisibility
vla-put-clippingenabled
vla-put-showrotation
vla-put-textcolor
vla-put-textposition
vla-put-textrotation
vla-put-textalignmentpoint
vla-put-textgap
vla-put-textfont
vla-put-bigfontfile
vla-put-fontfile
vla-put-textfontsize
vla-put-textfontstyle
vla-put-textprefix
vla-put-textsuffix
vla-put-tolerancejustification
vla-put-tolerancedisplay
vla-put-textmovement
vla-put-textoverride
vla-put-textstyle
vla-put-textheight
vla-put-horizontaltextposition
vla-put-verticaltextposition
vla-put-suppresszerofeet
vla-put-suppresszeroinches
vla-put-arrowheadsize
vla-put-arrowheadtype
vla-put-arrowheadblock
vla-put-arrowhead1type
vla-put-arrowhead1block
vla-put-arrowhead2type
vla-put-arrowhead2block
vla-put-arcpoint
vla-put-centerpoint
vla-put-leader1point
vla-put-leader2point
vla-put-ispartial
vla-put-arcstartparam
vla-put-arcendparam
vla-put-hasleader
vla-put-symbolposition
vla-put-textprecision
vla-put-dimlineinside
vla-put-forcelineinside
vla-put-textinside
vla-put-textinsidealign
vla-put-textoutsidealign
vla-put-dimensionlinecolor
vla-put-dimensionlineweight
vla-put-dimensionlinetype
vla-put-dimensionlineextend
vla-put-extensionlinecolor
vla-put-extensionlineweight
vla-put-extensionlineextend
vla-put-extensionlineoffset
vla-put-dimlinesuppress
vla-put-dimline1suppress
vla-put-dimline2suppress
vla-put-extline1suppress
vla-put-extline2suppress
vla-put-fit
vla-put-unitsformat
vla-put-linearscalefactor
vla-put-rounddistance
vla-put-extline1point
vla-put-extline2point
vla-put-extline1startpoint
vla-put-extline2startpoint
vla-put-extline1endpoint
vla-put-extline2endpoint
vla-put-extline1linetype
vla-put-extline2linetype
vla-put-extlinefixedlensuppress
vla-put-textfill
vla-put-textfillcolor
vla-put-angleformat
vla-put-anglevertex
vla-put-tolerancesuppresszerofeet
vla-put-tolerancesuppresszeroinches
vla-put-toleranceprecision
vla-put-toleranceheightscale
vla-put-tolerancelowerlimit
vla-put-centertype
vla-put-centermarksize
vla-put-suppressleadingzeros
vla-put-suppresstrailingzeros
vla-put-tolerancesuppressleadingzeros
vla-put-tolerancesuppresstrailingzeros
vla-put-primaryunitsprecision
vla-put-fractionformat
vla-put-altunits
vla-put-altunitsprecision
vla-put-altunitsscale
vla-put-altunitsformat
vla-put-altrounddistance
vla-put-alttextprefix
vla-put-alttextsuffix
vla-put-alttoleranceprecision
vla-put-altsuppressleadingzeros
vla-put-altsuppresstrailingzeros
vla-put-altsuppresszerofeet
vla-put-altsuppresszeroinches
vla-put-alttolerancesuppressleadingzeros
vla-put-alttolerancesuppresstrailingzeros
vla-put-alttolerancesuppresszerofeet
vla-put-alttolerancesuppresszeroinches
vla-put-leaderlength
vla-put-overridecenter
vla-put-joglocation
vla-put-jogangle
vla-put-chordpoint
vla-put-decimalseparator
vla-put-name
vla-put-description
vla-put-categoryname
vla-put-layoutid
vla-put-layerstate
vla-put-hasvpassociation
vla-put-path
vla-put-menufile
vla-put-largebuttons
vla-put-left
vla-put-top
vla-put-floatingrows
vla-put-orthoon
vla-put-gridon
vla-put-viewporton
vla-put-displaylocked
vla-put-standardscale
vla-put-customscale
vla-put-xscalefactor
vla-put-yscalefactor
vla-put-zscalefactor
vla-put-xeffectivescalefactor
vla-put-yeffectivescalefactor
vla-put-zeffectivescalefactor
vla-put-value
vla-put-scalewidth
vla-put-scaleheight
vla-put-lockaspectratio
vla-put-oleitemtype
vla-put-oleplotquality
vla-put-olesourceapp
vla-put-comments
vla-put-units
vla-put-explodable
vla-put-blockscaling
vla-put-direction
vla-put-xvector
vla-put-yvector
vla-put-directionvector
vla-put-columns
vla-put-columnspacing
vla-put-rows
vla-put-rowspacing
vla-put-translateids
vla-put-mask
vla-put-shadowdisplay
vla-put-normal
vla-put-elevation
vla-put-elevationmodelspace
vla-put-elevationpaperspace
vla-put-objectsnapmode
vla-put-snapbasepoint
vla-put-snaprotationangle
vla-put-snapon
vla-put-ucsiconon
vla-put-ucsiconatorigin
vla-put-twistangle
vla-put-lenslength
vla-put-target
vla-put-arcsmoothness
vla-put-shadeplot
vla-put-ucsperviewport
vla-put-modelview
vla-put-sheetview
vla-put-labelblockid
vla-put-label
vla-put-enable
vla-put-check
vla-put-macro
vla-put-helpstring
vla-put-endsubmenulevel
vla-item
vla-activate
vla-update
vla-erase
vla-highlight
vla-delete
vla-explode
vla-offset
vla-copy
vla-getattributes
vla-getconstantattributes
vla-getextensiondictionary
vla-scaleentity
vla-move
vla-rotate
vla-rotate3d
vla-mirror
vla-mirror3d
vla-intersectwith
vla-attachexternalreference
vla-reload
vla-unload
vla-detach
vla-bind
vla-fieldcode
vla-generateusagedata
vla-getdynamicblockproperties
vla-resetblock
vla-converttoanonymousblock
vla-converttostaticblock
vla-syncmodelview
vla-setnames
vla-setrgb
vla-setcolorbookcolor
vla-numcustominfo
vla-setcustombyindex
vla-setcustombykey
vla-addcustominfo
vla-removecustombyindex
vla-removecustombykey
vla-getcustombyindex
vla-getcustombykey
vla-addobject
vla-addxrecord
vla-addpviewport
vla-addcustomobject
vla-add3dface
vla-add3dmesh
vla-add3dpoly
vla-addarc
vla-addattribute
vla-addbox
vla-addcircle
vla-addcone
vla-addcylinder
vla-addellipse
vla-addellipticalcone
vla-addellipticalcylinder
vla-addextrudedsolid
vla-addextrudedsolidalongpath
vla-addleader
vla-addmleader
vla-addmtext
vla-addpoint
vla-addlightweightpolyline
vla-addpolyline
vla-addray
vla-addregion
vla-addrevolvedsolid
vla-addshape
vla-addsolid
vla-addsphere
vla-addspline
vla-addtext
vla-addtolerance
vla-addtorus
vla-addtrace
vla-addwedge
vla-addxline
vla-addhatch
vla-addraster
vla-addline
vla-addminsertblock
vla-addpolyfacemesh
vla-addmline
vla-adddim3pointangular
vla-adddimaligned
vla-adddimangular
vla-adddimdiametric
vla-adddimrotated
vla-adddimordinate
vla-adddimradial
vla-add-dimradiallarge
vla-add-dimarc
vla-addtable
vla-addsection
vla-copyfrom
vla-insertblock
vla-getinvisibleedge
vla-setinvisibleedge
vla-getwidth
vla-setwidth
vla-getbulge
vla-setbulge
vla-getweight
vla-setweight
vla-getcontrolpoint
vla-setcontrolpoint
vla-getfitpoint
vla-setfitpoint
vla-addfitpoint
vla-deletefitpoint
vla-purgefitdata
vla-setpattern
vla-evaluate
vla-appendinnerloop
vla-appendouterloop
vla-insertloopat
vla-getloopat
vla-appendvertex
vla-addvertex
vla-elevateorder
vla-movetobottom
vla-movetotop
vla-movebelow
vla-moveabove
vla-swaporder
vla-block
vla-getfulldraworder
vla-getrelativedraworder
vla-setrelativedraworder
vla-getcolumnwidth
vla-setcolumnwidth
vla-getrowheight
vla-setrowheight
vla-getcontentcolor
vla-setcontentcolor
vla-cleartablestyleoverrides
vla-getcelltype
vla-setcelltype
vla-getcellextents
vla-getattachementpoint
vla-getcellalignment
vla-setcellalignment
vla-getcellbackgroundcolornone
vla-setcellbackgroundcolornone
vla-getcellcontentcolor
vla-setcellcontentcolor
vla-getcellstyleoverrides
vla-deletecellcontent
vla-getrowtext
vla-gettext
vla-settext
vla-getcelltextstyle
vla-setcelltextstyle
vla-getcelltextheight
vla-setcelltextheight
vla-gettextrotation
vla-settextrotation
vla-getautoscale
vla-setautoscale
vla-getblocktablerecordid
vla-setblocktablerecordid
vla-getblockscale
vla-setblockscale
vla-getblockrotation
vla-setblockrotation
vla-getblockattributevalue
vla-setblockattributevalue
vla-getcellgridlineweight
vla-setcellgridlineweight
vla-getcellgridlcolor
vla-setcellgridlcolor
vla-getcellgridvisibility
vla-setcellgridvisibility
vla-insertcolumns
vla-insertrows
vla-deletecolumns
vla-deleterows
vla-mergecells
vla-unmergecells
vla-ismergedcell
vla-getfieldid
vla-setfieldid
vla-generatelayout
vla-recomputetableblock
vla-hittest
vla-selectsubregion
vla-reselectsubregion
vla-getsubselection
vla-setsubselection
vla-clearsubselection
vla-boolean
vla-checkinterference
vla-sectionsolid
vla-slicesolid
vla-arraypolar
vla-arrayrectangular
vla-transformby
vla-getxdata
vla-setxdata
vla-getxrecorddata
vla-setxrecorddata
vla-setdatabase
vla-deleteprofile
vla-resetprofile
vla-importprofile
vla-exportprofile
vla-renameprofile
vla-getallprofilenames
vla-getboundingbox
vla-getgridspacing
vla-setgridspacing
vla-getsnapspacing
vla-setsnapspacing
vla-getucsmatrix
vla-split
vla-setview
vla-deleteconfiguration
vla-display
vla-clipboundary
vla-getvariable
vla-setvariable
vla-getacadstate
vla-sendcommand
vla-regen
vla-auditinfo
vla-purgeall
vla-startundomark
vla-endundomark
vla-loadshapefile
vla-wblock
vla-export
vla-import
vla-getplotdevicenames
vla-refreshplotdeviceinfo
vla-getcanonicalmedianames
vla-getplotstyletablenames
vla-getlocalemedianame
vla-getpapermargins
vla-getpapersize
vla-getwindowtoplot
vla-setwindowtoplot
vla-getcustomscale
vla-setcustomscale
vla-displayplotpreview
vla-plottofile
vla-plottodevice
vla-setlayoutstoplot
vla-startbatchmode
vla-float
vla-dock
vla-addsubmenu
vla-addtoolbarbutton
vla-addseparator
vla-insertinmenubar
vla-removefrommenubar
vla-insertmenuinmenubar
vla-removemenufrommenubar
vla-getbitmaps
vla-setbitmaps
vla-attachtoolbartoflyout
vla-add
vla-load
vla-additems
vla-removeitems
vla-appenditems
vla-clear
vla-select
vla-selectatpoint
vla-selectbypolygon
vla-selectonscreen
vla-rename
vla-remove
vla-replace
vla-getobject
vla-getname
vla-reverse
vla-restore
vla-copyobjects
vla-getfont
vla-setfont
vla-getentity
vla-getsubentity
vla-prompt
vla-angletoreal
vla-angletostring
vla-distancetoreal
vla-realtostring
vla-translatecoordinates
vla-initializeuserinput
vla-getinteger
vla-getinput
vla-getkeyword
vla-getstring
vla-getangle
vla-getcorner
vla-getdistance
vla-getorientation
vla-getpoint
vla-polarpoint
vla-anglefromxaxis
vla-isurl
vla-putremotefile
vla-getremotefile
vla-isremotefile
vla-launchbrowserdialog
vla-sendmodelessoperationstart
vla-sendmodelessoperationended
vla-createtypedarray
vla-gettextstyle
vla-settextstyle
vla-gettextheight
vla-settextheight
vla-getalignment
vla-setalignment
vla-getcolor
vla-setcolor
vla-getbackgroundcolor
vla-setbackgroundcolor
vla-getbackgroundcolornone
vla-setbackgroundcolornone
vla-getgridlineweight
vla-setgridlineweight
vla-getgridcolor
vla-setgridcolor
vla-getgridvisibility
vla-setgridvisibility
vla-loadads
vla-loadarx
vla-unloadads
vla-unloadarx
vla-listads
vla-listarx
vla-loaddvb
vla-unloaddvb
vla-runmacro
vla-zoomall
vla-zoomextents
vla-zoomprevious
vla-zoompickwindow
vla-zoomcenter
vla-zoomscaled
vla-zoomwindow
vla-open
vla-save
vla-saveas
vla-close
vla-quit
vlax-product-key
vlax-get-acad-object
vlax-get-object
vlax-create-object
vlax-get-or-create-object
vlax-release-object
vlax-object-released-p
vlax-typeinfo-available-p
vlax-property-available-p
vlax-method-applicable-p
vlax-import-type-library
vlax-get
vlax-get-property
vlax-put
vlax-put-property
vlax-invoke-method
vlax-dump-object
vlax-add-cmd
vlax-remove-cmd
vlax-queueexpr
vlax-2d-point
vlax-3d-point
vlax-ename->vla-object
vlax-vla-object->ename
vlax-erased-p
vlax-read-enabled-p
vlax-write-enabled-p
vlax-for
vlax-map-collection
vlax-make-safearray
vlax-make-variant
vlax-variant-type
vlax-variant-value
vlax-variant-change-type
vlax-safearray-fill
vlax-safearray-get-dim
vlax-safearray-get-l-bound
vlax-safearray-get-u-bound
vlax-safearray-type
vlax-safearray->list
vlax-safearray-get-element
vlax-safearray-put-element
vlax-tmatrix
vlax-curve-getarea
vlax-curve-getstartparam
vlax-curve-getendparam
vlax-curve-getstartpoint
vlax-curve-getendpoint
vlax-curve-getdistatparam
vlax-curve-getparamatdist
vlax-curve-getdistatpoint
vlax-curve-getpointatdist
vlax-curve-getparamatpoint
vlax-curve-getpointatparam
vlax-curve-getfirstderiv
vlax-curve-getsecondderiv
vlax-curve-isclosed
vlax-curve-isperiodic
vlax-curve-isplanar
vlax-curve-getclosestpointto
vlax-curve-getclosestpointtoprojection
vlax-ldata-put
vlax-ldata-get
vlax-ldata-list
vlax-ldata-delete
vlax-ldata-test
vlisp-import-symbol
vlisp-export-symbol
vlisp-import-exsubrs
:vlax-null
:vlax-true
:vlax-false
:constants-prefix
:methods-prefix
:properties-prefix
:tlb-filename
:prog-id
vlax-vbabort
vlax-vbabortretryignore
vlax-vbapplicationmodal
vlax-vbarchive
vlax-vbarray
vlax-vbboolean
vlax-vbcancel
vlax-vbcritical
vlax-vbcurrency
vlax-vbdataobject
vlax-vbdate
vlax-vbdefaultbutton1
vlax-vbdefaultbutton2
vlax-vbdefaultbutton3
vlax-vbdirectory
vlax-vbdouble
vlax-vbempty
vlax-vberror
vlax-vbexclamation
vlax-vbhidden
vlax-vbhiragana
vlax-vbignore
vlax-vbinformation
vlax-vbinteger
vlax-vbkatakana
vlax-vblong
vlax-vblowercase
vlax-vbnarrow
vlax-vbno
vlax-vbnormal
vlax-vbnull
vlax-vbobject
vlax-vbok
vlax-vbokcancel
vlax-vbokonly
vlax-vbpropercase
vlax-vbquestion
vlax-vbreadonly
vlax-vbretry
vlax-vbretrycancel
vlax-vbsingle
vlax-vbstring
vlax-vbsystem
vlax-vbsystemmodal
vlax-vbuppercase
vlax-vbvariant
vlax-vbvolume
vlax-vbwide
vlax-vbyes
vlax-vbyesno
vlax-vbyesnocancel
ac0degrees
ac100_1
ac10_1
ac180degrees
ac1ft_1ft
ac1in_1ft
ac1_1
ac1_10
ac1_100
ac1_128in_1ft
ac1_16
ac1_16in_1ft
ac1_2
ac1_20
ac1_2in_1ft
ac1_30
ac1_32in_1ft
ac1_4
ac1_40
ac1_4in_1ft
ac1_50
ac1_64in_1ft
ac1_8
ac1_8in_1ft
ac270degrees
ac2_1
ac3dface
ac3dpolyline
ac3dsolid
ac3in_1ft
ac3_16in_1ft
ac3_32in_1ft
ac3_4in_1ft
ac3_8in_1ft
ac4_1
ac6in_1ft
ac8_1
ac90degrees
acabove
acactiveviewport
acalignmentaligned
acalignmentbottomcenter
acalignmentbottomleft
acalignmentbottomright
acalignmentcenter
acalignmentfit
acalignmentleft
acalignmentmiddle
acalignmentmiddlecenter
acalignmentmiddleleft
acalignmentmiddleright
acalignmentright
acalignmenttopcenter
acalignmenttopleft
acalignmenttopright
acalignpntacquisitionautomatic
acalignpntacquisitionshifttoacquire
acallviewports
acarc
acarchitectural
acarrowarchtick
acarrowboxblank
acarrowboxfilled
acarrowclosed
acarrowclosedblank
acarrowdatumblank
acarrowdatumfilled
acarrowdefault
acarrowdot
acarrowdotblank
acarrowdotsmall
acarrowintegral
acarrownone
acarrowoblique
acarrowopen
acarrowopen30
acarrowopen90
acarroworigin
acarroworigin2
acarrowsmall
acarrowsonly
acarrowuserdefined
acattachmentpointbottomcenter
acattachmentpointbottomleft
acattachmentpointbottomright
acattachmentpointmiddlecenter
acattachmentpointmiddleleft
acattachmentpointmiddleright
acattachmentpointtopcenter
acattachmentpointtopleft
acattachmentpointtopright
acattribute
acattributemodeconstant
acattributemodeinvisible
acattributemodepreset
acattributemodeverify
acattributereference
acbasemenugroup
acbestfit
acbeziersurfacemesh
acblockreference
acblue
acbottomtotop
acbyblock
acbylayer
acbystyle
accenterline
accentermark
accenternone
accircle
accubicspline3dpoly
accubicsplinepoly
accubicsurfacemesh
accyan
acdecimal
acdefaultunits
acdegreeminuteseconds
acdegrees
acdemandloadcmdinvoke
acdemandloaddisabled
acdemandloadenabled
acdemandloadenabledwithcopy
acdemandloadonobjectdetect
acdemanloaddisable
acdiagonal
acdim3pointangular
acdimaligned
acdimangular
acdimarchitectural
acdimarchitecturalstacked
acdimdecimal
acdimdiametric
acdimengineering
acdimfractional
acdimfractionalstacked
acdimlarchitectural
acdimldecimal
acdimlengineering
acdimlfractional
acdimlinewithtext
acdimlscientific
acdimlwindowsdesktop
acdimordinate
acdimprecisionzero
acdimprecisionone
acdimprecisiontwo
acdimprecisionthree
acdimprecisionfour
acdimprecisionfive
acdimprecisionsix
acdimprecisionseven
acdimprecisioneight
acdimradial
acdimrotated
acdimscientific
acdimwindowsdesktop
acdisplay
acdisplaydcs
acdragdisplayautomatically
acdragdisplayonrequest
acdragdonotdisplay
acellipse
acengineering
acenglish
acextendboth
acextendnone
acextendotherentity
acextendthisentity
acextents
acexternalreference
acfalse
acfirstextensionline
acfitcurvepoly
acfontbold
acfontbolditalic
acfontitalic
acfontregular
acfractional
acfullpreview
acgrads
acgreen
acgroup
achatch
achatchlooptypedefault
achatchlooptypederived
achatchlooptypeexternal
achatchlooptypepolyline
achatchlooptypetextbox
achatchpatterntypecustomdefined
achatchpatterntypepredefined
achatchpatterntypeuserdefined
achatchstyleignore
achatchstylenormal
achatchstyleouter
achorizontal
achorizontalalignmentaligned
achorizontalalignmentcenter
achorizontalalignmentfit
achorizontalalignmentleft
achorizontalalignmentmiddle
achorizontalalignmentright
achorzcentered
acinches
acinsertunitsangstroms
acinsertunitsastronomicalunits
acinsertunitsautoassign
acinsertunitscentimeters
acinsertunitsdecameters
acinsertunitsdecimeters
acinsertunitsfeet
acinsertunitsgigameters
acinsertunitshectometers
acinsertunitsinches
acinsertunitskilometers
acinsertunitslightyears
acinsertunitsmeters
acinsertunitsmicroinches
acinsertunitsmicrons
acinsertunitsmiles
acinsertunitsmillimeters
acinsertunitsmils
acinsertunitsnanometers
acinsertunitsparsecs
acinsertunitsprompt
acinsertunitsunitless
acinsertunitsyards
acintersection
acjis
ackeyboardentry
ackeyboardentryexceptscripts
ackeyboardrunningobjsnap
aclayout
acleader
aclefttoright
aclimits
acline
aclinenoarrow
aclinespacingstyleatleast
aclinespacingstyleexactly
aclinewitharrow
aclnwt000
aclnwt005
aclnwt009
aclnwt013
aclnwt015
aclnwt018
aclnwt020
aclnwt025
aclnwt030
aclnwt035
aclnwt040
aclnwt050
aclnwt053
aclnwt060
aclnwt070
aclnwt080
aclnwt090
aclnwt100
aclnwt106
aclnwt120
aclnwt140
aclnwt158
aclnwt200
aclnwt211
aclnwtbyblock
aclnwtbylayer
aclnwtbylwdefault
acmagenta
acmax
acmenufilecompiled
acmenufilesource
acmenuitem
acmenuseparator
acmenusubmenu
acmetric
acmillimeters
acmin
acminsertblock
acmline
acmodelspace
acmovetextaddleader
acmovetextnoleader
acmtext
acnative
acnorm
acnotstacked
acoff
acon
acoqgraphics
acoqhighphoto
acoqlineart
acoqphoto
acoqtext
acoutside
acoverfirstextension
acoversecondextension
acpalettebydrawing
acpalettebysession
acpaperspace
acpaperspacedcs
acpartialmenugroup
acpartialpreview
acpenwidth013
acpenwidth018
acpenwidth025
acpenwidth035
acpenwidth050
acpenwidth070
acpenwidth100
acpenwidth140
acpenwidth200
acpenwidthunk
acpixels
acplotorientationlandscape
acplotorientationportrait
acpoint
acpolicylegacydefault
acpolicylegacylegacy
acpolicylegacyquery
acpolicynewdefault
acpolicynewlegacy
acpolyfacemesh
acpolyline
acpolylinelight
acpolymesh
acpreferenceclassic
acpreferencecustom
acprinteralertonce
acprinteralwaysalert
acprinterneveralert
acprinterneveralertlogonce
acproxyboundingbox
acproxynotshow
acproxyshow
acpviewport
acquadspline3dpoly
acquadsplinepoly
acquadsurfacemesh
acr12_dxf
acr13_dwg
acr13_dxf
acr14_dwg
acr14_dxf
acr15_dwg
acr15_dxf
acr15_template
acradians
acraster
acray
acred
acregion
acrighttoleft
acscaletofit
acscientific
acsecondextensionline
acselectionsetall
acselectionsetcrossing
acselectionsetcrossingpolygon
acselectionsetfence
acselectionsetlast
acselectionsetprevious
acselectionsetwindow
acselectionsetwindowpolygon
acshape
acsimple3dpoly
acsimplemesh
acsimplepoly
acsolid
acspline
acsplinenoarrow
acsplinewitharrow
acsubtraction
actext
actextandarrows
actextflagbackward
actextflagupsidedown
actextonly
actolbasic
actolbottom
actoldeviation
actolerance
actollimits
actolmiddle
actolnone
actolsymmetrical
actoltop
actoolbarbutton
actoolbarcontrol
actoolbardockbottom
actoolbardockleft
actoolbardockright
actoolbardocktop
actoolbarfloating
actoolbarflyout
actoolbarseparator
actoptobottom
actrace
actrue
acucs
acunion
acunknown
acvertcentered
acverticalalignmentbaseline
acverticalalignmentbottom
acverticalalignmentmiddle
acverticalalignmenttop
acview
acviewport2horizontal
acviewport2vertical
acviewport3above
acviewport3below
acviewport3horizontal
acviewport3left
acviewport3right
acviewport3vertical
acviewport4
acvp100_1
acvp10_1
acvp1ft_1ft
acvp1in_1ft
acvp1_1
acvp1_10
acvp1_100
acvp1_128in_1ft
acvp1_16
acvp1_16in_1ft
acvp1_2
acvp1_20
acvp1_2in_1ft
acvp1_30
acvp1_32in_1ft
acvp1_4
acvp1_40
acvp1_4in_1ft
acvp1_50
acvp1_64in_1ft
acvp1_8
acvp1_8in_1ft
acvp2_1
acvp3in_1ft
acvp3_16in_1ft
acvp3_32in_1ft
acvp3_4in_1ft
acvp3_8in_1ft
acvp4_1
acvp6in_1ft
acvp8_1
acvpcustomscale
acvpscaletofit
acwhite
acwindow
acworld
acxline
acyellow
aczoomscaledabsolute
aczoomscaledrelative
aczoomscaledrelativepspace
Tell me about...
Copying Code Examples from the Bricscad Programmer’s Reference
Programming Overview of LISP (LISt Processing) Language
Bricscad™ is commercialized by Bricsys NV. Bricsys NV and Vondle NV are fully owned subsidiaries of Menhirs NV. © 2001- Menhirs NV - All rights reserved. |
