Sets or returns whether the Bricscad window should be maximized on startup.
Syntax
Where:
BooleanVariable determines whether the window is maximized (True) or not (False).
object is the ApplicationPreferences object.
Examples...
MaxAutoCADWindow property example
Bricscad™ is commercialized by Bricsys NV. Bricsys NV and Vondle NV are fully owned subsidiaries of Menhirs NV. © 2001- Menhirs NV - All rights reserved. |
