In the Settings Dialog you can:
Do one of the following:
Click the Settings tool button (
) on the Standard toolbar.
Choose Settings... in the Settings menu.
Type settings in the command bar, then press Enter.
(option) Choose a display mode by clicking the corresponding button in the Settings toolbar.
Categorized
Lists the settings by category: Drawing, Dimensions and Program Options.
Alphabetical
Lists the settings alphabetically.
(option) Choose a category:
Drawing (
Opens the Categorized view mode, with the Drawing settings tree expanded.
Dimensions (
Opens the Categorized view mode, with the Dimension settings tree expanded.
Program Options
Opens the Categorized view mode, with the Program Options settings tree expanded.
Open the Settings Dialog.
Select a setting.
1 |
Class: Drawing, Dimensions or Program Options |
2 |
Category (expanded) |
3 |
Sub-category (expanded) |
4 |
Group (expanded) |
5 |
Setting and its current value |
6 |
Options list |
7 |
Group (collapsed) |
8 |
Internal Name: System variable names are fully capitalized; user preferences are in lower case. You can type a variable name in the command window to edit the setting. |
9 |
Settings Name |
10 |
Settings Description |
11 |
Preview |
12 |
Settings Type ( |
13 |
Where is the setting saved?
14 |
Click the settings field to edit the setting.
(option) Repeat steps 3 and 4 to edit more settings.
Close the Settings window.
(option) Click the Find
Options button (
) to open the open the Find
Setting dialog where you can set the search options.
Type the search string in the Search field.
The first setting matching the content of the search field
highlights.
(option) Click the next (
) or previous (
) button to browse through the matching settings.
Click the Export tool
) on the Settings toolbar.
The Export Settings window opens.
Type a name in the File name field.
Select a folder.
Click the Save button
on the Export Settings
window.
All Settings are exported in a CSV (Comma
Separated Values) text file, which can be opened in Microsoft®
Excel®.
