Exploring Xrefs
In the Xrefs Explorer you can:
Open the Xrefs Explorer
To open the Xrefs Explorer do one of the following:
    go to top
Xrefs Explorer display options
You can choose between Detail View (list), Icon View and Tree View  to see the xrefs in the current drawing.
NOTE
Bricscad searches for external references in the folder of the parent drawing first. If the drawing is not found there, Bricscad looks in the Saved Path folder. If the drawing is not found there either, (! Not Found) displays in the Saved Path field.
Open the Detail View of the Xrefs Explorer
Click the Detail View button () in the Drawing Explorer toolbar. The Detail View button is now pressed (), indicating the Xref details are displayed.
The selected Xref displays in the Preview sub-window of the Drawing Explorer.
Detail view of the Xrefs in the current drawing
go to top
Open the Icon View of the Xrefs Explorer
Click the Icon View button () in the Drawing Explorer toolbar. The Icon View  button is now pressed (), indicating the Xref icons are displayed.
External References that were not found display with the default icon () in the Details sub-window of the Drawing Explorer window.
Icon view of the Xrefs in the current drawing
go to top
Open the Tree View of the Xrefs Explorer
Click the Tree View button () in the Drawing Explorer toolbar. The Tree View  button is now pressed (), indicating the Xref tree is displayed.
External References that were not found display with the error icon () in the Details sub-window of the Drawing Explorer window.
Tree view of the Xrefs in the current drawing
go to top
