Returns the extension dictionary associated with an object
Syntax
RetObject = object.GetExtensionDictionary
Where:
The object this method applies to;it can be one of the following:
All Drawing Objects, AttributeReference, Block, Dictionary, DimStyle, Group, Layer, Linetype, PlotConfigurations, RegisteredApplication, TextStyle, UCS, View, Viewport, Xrecord.
RetObject is Dictionary object
Examples...
GetExtensionDictionary method example
Bricscad™ is commercialized by Bricsys NV. Bricsys NV and Vondle NV are fully owned subsidiaries of Menhirs NV. Copyright © 2001- Menhirs NV - All rights reserved. |
