DimensionStyle object
Class AcadDimStyle
Member of BricscadDb
The DimStyle object contains the settings that determine the appearance of a dimension. To access the DimeStyle object, use the following methods and properties:
Methods Properties
Delete Application
GetExtensionDictionary Document
GetXData Handle
SetXData HasExtensionDictionary
  Name
  ObjectID
  ObjectName
  OwnerID
