The Window object represents an open window in a Bricscad session. To access the Window object, use the following methods and properties:
Methods | Properties |
Activate | Application |
Close | Caption |
GetWindowRect | Document |
Scroll | Parent |
SetWindowRect | Visible |
WindowHandle32 | |
WindowState |
Bricscad™ is commercialized by Bricsys NV. Bricsys NV and Vondle NV are fully owned subsidiaries of Menhirs NV. Copyright © 2001- Menhirs NV - All rights reserved. |
