TextGenerationFlag property
Sets or returns the text generation flags, using the TextFlag constants shown below. It is applicable to an Attribute, AttributeReference, or Text object.
Syntax
integerVariable = object.TextGenerationFlag
object.TextGenerationFlag = <integer>
Where:
     integerVariable is an Integer (or the constant itself) representing the TextFlag;
     Object is the name of a Text object or an object containing text.
TextFlag Constant Index Value
acTextFlagNormal
0
acTextFlagBackward
2
acTextFlagUpsideDown
4
