Class AcadText
Member of BricscadDb
The Text object represents single-line text. To create text, use the AddText method. To modify or obtain information about text, use the following methods and properties:
Methods | Properties | Events |
ArrayPolar | Alignment | Modified |
ArrayRectangular | Application | |
Copy | Backward | |
Delete | Document | |
GetBoundingBox | Handle | |
GetExtensionDictionary | HasExtensionDictionary | |
GetXData | Height | |
Highlight | Hyperlinks | |
IntersectWith | InsertionPoint | |
Mirror | Layer | |
Mirror3D | Linetype | |
Move | LinetypeScale | |
Rotate | Lineweight | |
Rotate3D | Material | |
ScaleEntity | Normal | |
SetXData | ObjectID | |
TransformBy | ObjectName | |
Update | ObliqueAngle | |
OwnerID | ||
PlotStyleName | ||
Rotation | ||
ScaleFactor | ||
StyleName | ||
TextAlignmentPoint | ||
TextGenerationFlag | ||
TextString | ||
Thickness | ||
TrueColor | ||
UpsideDown | ||
Visible |
Bricscad™ is commercialized by Bricsys NV. Bricsys NV and Vondle NV are fully owned subsidiaries of Menhirs NV. Copyright © 2001- Menhirs NV - All rights reserved. |
